rename - tab - GPS to Map
XnViewMP 1.8.0 64bit
Browser / Properties - tab
  • rename GPS to Map in
    - Browser > Info pane tab
    - Viewer > Image Properties tab
Re: rename - tab - GPS to Map
right better
done in 181
Nicolas
Post by Nicolas »
Sorry I don't know if this is where I should report the problem or by opening a new bug... I just noticed that in the french version this tab is now labeled "Table" which isn't at all informative :)
Nicolas wrote: Fri Nov 22, 2024 3:32 pm Sorry I don't know if this is where I should report the problem or by opening a new bug... I just noticed that in the french version this tab is now labeled "Table" which isn't at all informative :)
Please update to 1.8.3
Nicolas
Post by Nicolas »
It's already the case, I wouldn't have bothered you without having updated it first :)
CleanShot 2024-11-24 at 14.42.23@2x.png (4.98 KiB) Viewed 2807 times
ok, an error
