1.8.0 - viewer - change color depth - 32bit result when converting 8 to 24
XnViewMP 1.8.0 64bit
Viewer / Batch convert - change color depth
0. clean portable version
1. open test image (8bpp, palleted, yellow color is transparent) in Viewer
2. goto Change color depth
- select 24bit, any color (eg black)
- press OK
image will be converted to 32bit (transparency preserved)
expected result
image to be converted to 24bit, if index color is transparent - use color from "Change color depth"
if user wants to preserve transparency - 32bit has to be selected manually
Related
Re: 1.8.0 - viewer - change color depth - 32bit result when converting 8 to 24
fixed in 181
