I did some test with the export function from file menu.
During compression I see a long green bar over the destination picture.
Is it a progress bar or a bug?
In most cases I see a long bar for a long time and no change.
After a short time it disappear.
[SOLVED] 1.8.0 - Green bar in export preview?
masterjp
Re: 1.8.0 - Green bar in export preview?
progress bar
masterjp
Okay, thank you!
