[1.8] Can not install .deb Version on Linux Mint
MegaV0lt
Post by MegaV0lt »
I am unable to install the .deb-Version of XnViewMP on my Linux PC (Mint 22)
darkwing@darkwing-PC ~/src/radiotray-ng/build $ inxi -FxZ
System:
  Host: darkwing-PC Kernel: 6.8.0-45-generic arch: x86_64 bits: 64
    compiler: gcc v: 13.2.0
  Desktop: Cinnamon v: 6.2.9 Distro: Linux Mint 22 Wilma
    base: Ubuntu 24.04 noble
Machine:
  Type: Desktop System: New Solutions GmbH product: NTSI Contender E64 SC2i-M
    v: 23430001239200000000000000000000 serial: <superuser required>
  Mobo: ASUSTeK model: PRIME Z270M-PLUS v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 1205
    date: 05/14/2018
CPU:
  Info: quad core model: Intel Core i7-6700K bits: 64 type: MT MCP
    arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 8 MiB
  Speed (MHz): avg: 3900 high: 3902 min/max: 800/4200 cores: 1: 3900 2: 3900
    3: 3900 4: 3902 5: 3900 6: 3901 7: 3900 8: 3901 bogomips: 63999
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Graphics:
  Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
    arch: Gen-9 bus-ID: 00:02.0
  Display: x11 server: X.Org v: 21.1.11 with: Xwayland v: 23.2.6 driver: X:
    loaded: modesetting unloaded: fbdev,vesa dri: iris gpu: i915
    resolution: 2560x1440~60Hz
  API: EGL v: 1.5 drivers: iris,swrast platforms:
    active: x11,surfaceless,device inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.9-0ubuntu0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
Audio:
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
  API: ALSA v: k6.8.0-45-generic status: kernel-api
  Server-1: PipeWire v: 1.0.5 status: active
Network:
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full
    mac: 2c:4d:54:d1:58:0f
Drives:
  Local Storage: total: 1.36 TiB used: 1.05 TiB (77.1%)
  ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS500G2B0C-00PXH0
    size: 465.76 GiB temp: 38.9 C
  ID-2: /dev/sda vendor: Samsung model: HD103UJ size: 931.51 GiB
Partition:
  ID-1: / size: 195.32 GiB used: 25.08 GiB (12.8%) fs: ext4
    dev: /dev/nvme0n1p1
  ID-2: /boot/efi size: 499 MiB used: 6.1 MiB (1.2%) fs: vfat
    dev: /dev/nvme0n1p3
  ID-3: /home size: 260.53 GiB used: 168.29 GiB (64.6%) fs: ext4
    dev: /dev/nvme0n1p2
Swap:
  ID-1: swap-1 type: file size: 3.97 GiB used: 0 KiB (0.0%)
    file: /mnt/Daten/swapfile
Sensors:
  System Temperatures: cpu: 54.0 C mobo: N/A
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 32 GiB note: est. available: 31.16 GiB
    used: 16.94 GiB (54.4%)
  Processes: 369 Uptime: 2d 2h 12m Init: systemd target: graphical (5)
  Packages: 3114 Compilers: gcc: 13.2.0 Shell: Bash v: 5.2.21 inxi: 3.3.34
Screenshot of the error:
https://www.dropbox.com/scl/fi/vbn1y3jp ... ij8ucvkojs
Re: [1.8] Can not install .deb Version on Linux Mint
you need to force the install
