Background color - canvas - improve consistency
XnViewMP 1.8.0
General - canvas background color
there is inconsistency of the canvas background color applied to image when removing transparency (old thread):
- no single source of bg color
- sometimes its ignored and white color is used
0. have 2 test images in folder (PNGs: 8bit palleted+tRNS chunk, 32bit truecolor+alpha channel)
test_img_color_to_replace_transparency.zip
1. set custom canvas background color (Viewer > Edit > Background color...), eg orange
2. perform any one of the following actions:
Issue A - white color
  • 8bit image
    - Change color depth... > set 24bit, any color
    - Save into format that does not support transparency
    - Rotate... > set 45°, ☑ Use anti-aliasing
    - Offset... set any option for Empty area
    image will be converted to 24bit* (tRNS chunk deleted) - OK
    color of transparent index will be changed to white
    expected behavior
    Index color should be used (yellow in example file)
    * although it's not entirely clear why this is required in the case of Offset, eg Rotation w/o antialiasing can preserve 8bit-ness
  • 32bit image
    - Remove alpha channel
    - Change color depth... > set 32bit, ☑ Replace alpha for 32bit images
    alpha channel will be applied using white color as background
    expected behavior
    color from step1 should be used (orange in our case)
Issue B - custom color
  • 8bit
    - Rotate... > set 45° (tool's default bg - black)
    color of 1st index will be used by default, however
    once you set custom bg color in tool - only tool's color, but with some unexpected limitation (try to set pink, black will be used instead)
  • 32bit image
    - Change color depth... > 24bit (tool's default bg - white)
    - Canvas resize... (tool's default bg - black)
    - Rotate... > 45° (tool's default bg - black)
    expected behavior
    some consistency required here
    options:
    • single bg color
      single global variable for all tools to use
      pro: simple
      con: may have issues in batch convert
    • single bg color + master
      tools have individual color, but all updates when 'master' color changed (Viewer > Edit > Background color...)
    • single bg color + master + option
      same as above, plus add checkbox somewhere "Update background color for all tools" (or "Changing master background color updates all tools")
ps: worth mentioning that PNG has background color in spec, but it just seems to be ignored everywhere.
https://www.w3.org/TR/png-3/#apng-canvas wrote: The canvas is the area on the output device on which the frames are to be displayed. The contents of the canvas are not necessarily available to the decoder. If a bKGD chunk exists, it may be used to fill the canvas if there is no preferable background.
Related
