Mount a Diashow with images opened at the Tab Bar
josedumoretzsohn
Post by josedumoretzsohn »
A suggestion just occurred, to create the possibility of mounting a Diashow with the images shown in the Tab bar. If this is already possible, please tell me how. As far as I know, creating a Diashow can only occur from the Browser (Thumbnails) panel. My present procedure for mounting a Diashow with images opened and shown on the Tab bar is a somewhat complex and troublesome routine, taking 4 steps: (1) copy each image in the Tab bar to a common previously chosen folder, which will only function as a relay folder; (2) going back and forth, I find the name of each image in the relay folder; select it in the original folder where the images are and the .sld Diashow file will be saved; (3) in the original folder, I open Diashow dialogue, and save and run Diashow; (4) delete relay folder. Any guidance and/or the creation of a direct possibility from the Tab bar will be much appreciated and used. Thank you.
