1.8.0 - viewer - move to - tab remains after last file move
XnViewMP 1.8.0 64bit
Viewer - file operations - move to
tab remains open after the last file has been moved
0. have 2 files in folder
1. open any image in Viewer
2. press Alt+M and move image to different folder
file moves, filelist changes accordingly
3. press Alt+M and move last image to different folder
file moves, however
Viewer tab remains open with loaded image
expected behavior
something like this:
loaded image is not dirty
  • single file in filelist
    Viewer tab should be automatically closed
  • multiple files in filelist
    Viewer tab should switch to other file
loaded image is dirty (unsaved)
  • single/multiple files in filelist
    • file move performed inside the app
      popup dialog should appear (similar to the one when deleting unsaved file)
      "Would you like to discard changes and move <FILE>?" [Yes/No]
    • file move performed outside the app
      Viewer tab should remain open and show unsaved image
Related
gummiband
Re: 1.8.0 - viewer - move to - path is not updated after move
Post by gummiband »
might be related to this:
Subject: 1.8.0: only first file moved when move-renaming multiple files
XnView: MP 1.8.0 64 bit ; Libformat 7.192 ; Build date 30.Aug.2024 (portable version)
OS: Windows 10 64bit
Multiple files not moved when filename already exists at destination
Effect: when moving multiple files to a new folder, and the filenames already exists in the destination folder, only the first file is moved when the rename option is chosen, the rest of the files stay in the source directory.
1. have two folders with *multiple* files and same file names
2. in the browser select multiple files from folder A and drag&drop to folder B (or use the right-click "Move to...", same outcome)
3. duplicate file sub-window pops up with the option to replace/all, skip/all and rename
4. input a new name (i chose var1_<oldfilename>), click "rename", continue until all files have run through
Actual behavior (bug): only *the first* file is renamed and moved, *all others* stay in the source folder :bug:
Expected behavior: move *all* files to destination with the typed-in new name. XnView Classic 2.51.7 does not have this bug
Re: 1.8.0 - viewer - move to - tab remains after last file move
fixed in 181
