v1.8.x AVIF decoding slower then 1.7.2
VictorVG
Post by VictorVG »
Question, on forum.ru-board.com (rus) and more...
In version 1.8.0, something bad when decoding AVIF became much slower. Especially noticeable on large files. Returned 1.7.2 - everything is as it should.
no diagnostics, only user messages "v1.8.1 - also"...
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
VictorVG
Re: v1.8.x AVIF decoding slower then 1.7.2
Post by VictorVG »
Try compare load time Xnview MP 1.8.1 x64 and GIMP 2.10.38 x64 - about the same time - from the moment the send Open command is recounted until the picture on the screen in both has passed about 4 seconds.
Test file Media Info:
General
Complete name : example.avif
Format : avif
Codec ID : avif (avif/mif1/miaf/MA1A)
File size : 42.5 MiB
Format : AV1
Format/Info : AOMedia Video 1
Codec ID : av01
Width : 7 117 pixels
Height : 6 828 pixels
Bit depth : 8 bits
Stream size : 42.5 MiB (100%)
Color range : Full
Codec configuration box : av1C
libheif was updated, could you send me a big avif test file?
VictorVG
Post by VictorVG »
Ok! - https://www.upload.ee/files/17225068/example.avif.html
Test 2:
Compared. The first time after the launch of the XNVIEW MP, both 1.7.2 and 1.8.1 read it for a long time, if the file is closed and re -open, then at any next call the picture is drawn in a split second, and judging by the sound, at the first opening, there is an appeal to the HDD.
VictorVG
Post by VictorVG »
Ok! Big thanks!
This problem is supposed to be fixed in XnView MP 1.8.2. Please check and confirm the bug fix here.
VictorVG
Post by VictorVG »
Compared to 1.8.1, the opening time has sharply decreased. At the first opening, XnView MP 1.8.2 spends some time creating a sketch and its recording in the database, and then opens the file instantly. GIMP 2.10.38 even if it is already launched and performs the operation "Open - Close - Open the file" reads it noticeably longer. For verification, I used the same "example.avif". At the moment I am waiting for confirmation of correction from Benchmark on topic at forum.ru-board.com.
VictorVG
Post by VictorVG »
Benchmark confirmed the correction. FIXED
purpleguy
Post by purpleguy »
Thank you so much for this!
