I am moving some images to a new directory within XnView. When the directory structure is changed using XnView "Move To/Create folder" the Folders pane does not update. If I create a new sub-directory I can see the sub-directory in the Browser window by going to the parent directory but there seems to be no way get the Folders directory structure to update other than closing XnView down and restarting.
I am not sure whether this is a bug or whether there is a setting I need to switch on ?
XnView Browser does not update Folders directory list
mkc73
Re: XnView Browser does not update Folders directory list
with 1.8.1? you had this bug with previous version?
mkc73
Hi Pierre,
Currently on 1.8.0. This problem has been present for as long as I can remember.
regards
Martin
regards
Martin
please describe how to reproduce...
