MP 1.81 - Export dialog - JPEGLI XYB colorspace [Solved] wrong preview/colors [Solved]
masterjp
Post by masterjp »
First thanks for the latest update to version 1.81! I am very happy about the latest changes.
If I choose the "convert to XYB colorspace" in Export dialog for JPEGLI encoder format,
the preview shows a wrong preview. I hope you can fix it. Thank you!
XYB Colorspace format (Preview):
Disabled XYB Colorspace = correct colors
Kadet
Re: MP 1.81 - Export dialog - JPEGLI XYB colorspace wrong preview/colors
Post by Kadet »
It's happens if ICC color profile is OFF.
Go to settings and change it for ON.
masterjp
Re: [Solved]MP 1.81 - Export dialog - JPEGLI XYB colorspace wrong preview/colors
Post by masterjp »
Kadet, this is the correct solution. Now it works. Thank you! :)
