1.8.1: Tabs not hidden after restart
misao
Post by misao »
(Not a new bug)
1. Enabled setting: "Hide Tab header when only one is opened" (Settings: Interface > Tabs)
2. Hide Tabs (uncheck: View > Tab > Show)
3. Restart the program
Workaround: Disable the setting and it works as expected.
Re: 1.8.1: Tabs not hidden after restart
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
