Format Settings — Too many JPEG tabs
zecanard
Post by zecanard »
The Format Settings windows under File ⭢ Format Settings… ⭢ Write and XnView ⭢ Preferences… ⭢ Formats ⭢ Write are getting very crowded, and a result, the JPEG format tabs have become unreadable:
I believe these must be JPEG-2000, JPEG-LI and JPEG-XL? Is there a way to make those tabs larger, or to rename them to J2000, JLI, JXL?
I am on macOS Sequoia 15.1, but it’s been like this for a while. Thanks!
Re: Format Settings — Too many JPEG tabs
This is what I see in Linux Mint on a 1920x1080 pixel Full HD screen:
So I think that the issue in macOS lies elsewhere...
you need to resize the Settings dialog
