Windows 11
In the test folder there are two video files (1, 2) and two image files (3, 4).
When I click on movie 2, the movie is shown in the viewer tab, and the status at the bottom shows 2 out of the maximum number of files: 4. And now, when I click left in the navigation to show movie 1, nothing happens. When I click right on the navigation, the graphic file appears.
At this point I can't go back to movie 2 or see movie 1, only the graphics of 4.
If I open graphics 3 in viewer tab, I see 1/2 in the status at the bottom. At this point, using the navigation keys, I can only view graphics 4, and I cannot view videos.
1.8.2 – view tab don't see movies
Kadet
Re: 1.8.2 – view tab don't see movies
My ini file is attached.
Kadet
OK, I now know that if I set ON Video option, I can see video files in viewer tab after use navigation arrow/keys.
Your program has a lot of options, which on the one hand is a plus, but can also be confusing
yes you can configure video in browser and/or in viewer
