I'm not sure if this qualifies as a bug or not but I Noticed a change with version 1.8.2 64-bir libformat 7.196
So while viewing a photo if I crop it and press the right cursor key to move to the next picture (as always) it asks if I should save my changes. If I answer yes it saves the picture but does not move to the next photos like it did in the previous version.
If I choose don't save it does move to the next photo, just like it worked in the previous version.
I Noticed a change in new version, not sure it was intended
DoubleD
DoubleD
Re: I Noticed a change in new version, not sure it was intended
I just started to see this behavior. It was working in the previous version.
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
