I'm using Xconvert texture converter and I'm trying to convert a DDS Resident Evil 4 Wii HD texture pack down to a lower file size by converting it to JPG, lowing the quality within the JPG settings, then when that's done converting it to PNG format so it's a lower file size, for use with Dolphin VR.
Only problem is, converting it to JPG is causing a lot of the original textures to become all messed up. Like the text turning white or just blocks of color where it should be normal textures. Any way to prevent this in any of Xconverts settings? For example:
https://pdsoasis.github.io/xconvertex.jpg
Xconvert is causing my textures to come out all white! Help
legaiaflame
Re: Xconvert is causing my textures to come out all white! Help
if you convert it in PNG?
legaiaflame
No from DDS to JPG is causing the defects. Is there any way to convert it to JPG without whiting out the textures?
please post a sample filelegaiaflame wrote: Thu Oct 24, 2024 9:10 pm No from DDS to JPG is causing the defects. Is there any way to convert it to JPG without whiting out the textures?
