Subject: 1.81: Wrong Focus moving files in Fullscreen
XnView: MP 1.81 & 1.82 64 bit
OS: Windows 64bit
If moving a file in Fullscreen view the focus in the list moves up. This means that if you are on the first file in the list, you get a blank screen instead of the next file! If you are sorting many pictures this is a real issue!
Effect: New behaviour in version 1.81 and 1.82, sorting of many file ist very unpleasent!
1. Have a list of many picture-files
2. Go to the fist picture-file
3. View in fullscreen
4. Move file (Alt+M) somwhere
Actual behaviour (bug): Blank screen (focus above the list of files
Expected behaviour: Focus (ans so fullscreen view) goes to the next picture-file (non the new top of the list)
Riezi
Re: Wrong Focus moving files in Fullscreen
I can't reproduce in 1.8.2. Do you use F11 from browser?
Riezi
Im using XnView from Windows.
The problem is still the same in 183: after moving a picture file (in fullscreen mode and Alt+M), the focus moves not to the NEXT file in the list (how it should and did till version 181), instead to the one before. That means if you are (or reach) the top of a list, you now see a black screen, because the focus is in the folder up line!!!
So you can not sort a list of pictures (in fullscreen mode as I always do) !!! Every time you reach the top of the list, you get a black screen!!!
This only happens if you are in Fullscreen mode (not in the list view, there moving files works fine).
Thank you for correcting this behavior! Please, I need to sort lists of files!
183
there is something..
1. open folder with few files in Browser
2. open any file in fullscreen
3. press Alt+M and move file somewhere
file moves, another file opens - OK
4. press Alt+M again
nothing happens
no issue is you manually navigate to another file after step 3
Do you launch fullscreen from browser or image's tab?
Please send us your xnview.ini
Riezi
Is the error solved now?
Yes, I am in browser-view and select the picture-file on top of the list.
F11 -> picture in fullscreen
Alt+M -> select destination path & OK (picture moved correctly)
Now I see a blank screen. If i change to browser (F11) the focus is in the 'level up' line above the list of files.
Thanks for checking that in the next version.
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
