Too small fonts not only on 4k (150% or 175% scaling). How to make bigger fonts?
xinni
Post by xinni »
please see the screenshot.
I did search the options for "font" and here in the forum I only found this thread and both did not help me to get a usable/readable fontsize on my windows 11 system on a 4k display with 150/175% scaling.
I have 2 monitors and on both the fontsize is very small/unreadable to my old eyes 8-]
I also tried to remove all the "font" entries in the xnview.ini, but that made it even worse to look at.
Here are the settings for both the monitors.
Any hints/ideas, so I can use xnviewMP again?
Even the About screen is barely readable to me:
Thank you! :shock: (not shocked, but only big eyes 8) )
EDIT: Maybe some more screenshots:
This looks good readable to me:
while those are really hard to read:
Steerpike
Re: Too smal fonts not only on 4k (150% or 175% scaling). How to make bigger fonts?
Post by Steerpike »
I've just started using XnView on a 2560x1600 screen, with 150% scaling, (windows 11) and the display is just tolerable, so I sympathize with you. I'm going to follow this thread with interest.
This app is not alone, though - even photoshop elements struggles with proper font scaling, and Quicken is an embarrassment (for such an expensive product).
BTW - '4k' is not intuitive to me (I view it as marketing hype); I always talk in terms of x/y screen dimensions (2560x1600, etc). (UPDATE - I see from your screenshot that you have a 3840x2160 display; so the '4k' is presumably a nominal reference to the 3,840 pixels ... )
xinni
Post by xinni »
Steerpike wrote: Fri Nov 01, 2024 5:30 am BTW - '4k' is not intuitive to me (I view it as marketing hype); I always talk in terms of x/y screen dimensions (2560x1600, etc). (UPDATE - I see from your screenshot that you have a 3840x2160 display; so the '4k' is presumably a nominal reference to the 3,840 pixels ... )
Actually, I have no idea. It was sold as "4k" and thats almost better to say or write "I have a display that supports a resolution of 3840x2160 pixels." So I stick to 4k and everyone knows what I'm talking about, I hope.
Back to the topic, I guess, that the problem is not the pixelcount, but more that all those smallish shown elements are not coded scalable and use either hardcoded scaling/fontsize or a font+size, which is not available to the user via GUI or .INI
So that (and yes, XNView is not the only program here) seems to me like a lot of work for the developer(s) to find all the code and update it, and I sadly guess, it's unlikely that it will be accomplished in the next five years. (Similar to the dark-mode thing, apple invented and now every program "needs" to have it, because the users are shouting about it. It is a timeconsuming and diligent work.)
Well, that was OT, so lets hope we can help and support here!
Steerpike
Re: Too small fonts not only on 4k (150% or 175% scaling). How to make bigger fonts?
Post by Steerpike »
What is the physical size of your 4k monitor? Is it a 27" monitor, a 42" monitor, etc? This would be the diagonal measurement, corner to corner. I'm working right now on my built-in laptop screen which is 17". It's the combination of 'resolution' (your '4k' terminology, or my '2560x1600' terminology - same thing) and physical size that leads to issues. My '2560x1600' resolution is barely readable on a 17" screen, but I have font-scaling set to 150% so that helps.
Ironically, buying a 'high res' monitor that has small physical dimensions is a recipe for disappointment. For the longest time, I wouldn't go above 1920x1200 on any laptop due to poor scaling support. Only recently has Windows finally built in some really good scaling support, and that's why this new laptop is now 2560x1600. But, as noted, Quicken and Photoshop are still not very usable - they worked much better when I had a 1920x1200 screen ("FHD" I believe is the buzzword for that res).
One thing I've noticed - programs that work on both Apple and Windows platforms seem to have more of an issue with this. I'm guessing that the way Windows handles scaling is totally different from the way Apple handles it, and if the developer wants to maintain a common code-base, the Windows display suffers. How else can Photoshop - which is an extremely expensive and 'high end' product - have such a hard time dealing with font scaling on Windows!
In Photoshop Elements (I can't justify the cost of the full Photoshop these days), they have a feature where you can change font sizes in the UI but - 'large' (200%) is ridiculously large (almost cartoonish), while 'small' (100%) is too small. For some reason, they can't provide a user-defined scaling factor, and ... I guess offering 150% would be just too much work!
This is Photoshop Elements 2023 at 100% scaling - the menu bar at the top is virtually unreadable on my screen:
And this is the EXACT same screen in PE at 200% scaling - the menus and fonts are so big, there's no room left for the actual image!
I don't think this is off topic at all, though - my guess is, the developers of XnView are running into the same issues that Photoshop is running into; they are using some libraries that are common between MacOS and Windows and they just don't handle scaling well. If Adobe can't fix this, not much hope for a freeware program like XnView perhaps. I hope I'm wrong! Actually - for me - XnView is MUCH BETTER than Photoshop in terms of UI scaling; but I think in your case, your monitor is such high resolution that you are inadvertently suffering.
eyk
Post by eyk »
Hey, sorry to bump this, but I am facing the same problem. Is there any fix available? Thanks.
Bigglesworth
Post by Bigglesworth »
I cannot believe this still has not been fixed. Its 2026, people are moving away from 1080p. Proper GUI scaling has been a basic option like darkmode for almost two decades now. On 4K 98% of applications i use are scaled properly at 125% windows scaling except a few applications LIKE THIS ONE.
Its ironic because this is a visual oriented application.
Its time to beautify your application that youve worked for so long on. It deserves it.
mrwul
Post by mrwul »
I definitely agree...
31.5" 3840 × 2160 fontscale at 125%
mrwul
Post by mrwul »
Sorry, but eh..why?
Reason for asking: I really don't know what QT6 is.
I checked the discussion on QT and search for 'font'.
It does not show up.
So, TBH, I am not sure what I am doing when stalling QT6.
BTW I explored a few other options, like
XnViewMP.exe → Properties → Compatibility → “Change high DPI settings” → Override scaling behavior.
and
increase scale in Settings > System > Display > Scale
and
Settings → Accessibility → Text size → Increase to (e.g.) 110 but that is system wide.
I let it rest.
I believe XnViewMP is not the only one having issues with HD monitors.
Same goes for old Photoshop CS6 (there is a setting to set the Interface font size to large. The size of all the drop down menu items are okay, but the toolbar, the layers panel, etc. they still remain very tiny.
I can understand it: Photoshop CS6 is old - last non subscription version, no updates already for a long time, so this will never be fixed.
Anyway, as said, I let it rest.
in case of need, call in the Windows magnifier (Win+Plus) :-)
