A swedish flag!!!
Tasseman
A swedish flag!!!
Post by Tasseman »
Hallo!
In your downloadsite I can see a swedish flag.
In version 1.80.3 I can not find the swedish language.
In another forum I can read that you have found a swedish translator in june 2005.
When will it be possible to run 1.80.3 in swedish.
I have an earlier version. It was in swedish.
Until you have a swedish version I suggest that you remove the swedish flag!!!
It is not fair. :( :(
Best,
SW
Sören Wallin
Sweden
Re: A swedish flag!!!
Tasseman wrote:Hallo!
You have swedish dll in full package or language package.
Tasseman
A swedish flag!!!
Post by Tasseman »
Hallo Pierre!!
Thank you very much for your answer.
Now it is fixed. I have the swedish version.
When I downloaded your Setup (Multilanguage) 3,3Mb I got 33 language. Not Swedish.
When I downloaded your Language pack I got 45 language. 12 more. One of them was swedish. So the swedish version is not included in your standard multilanguage version. I downloaded the standard version app. one hour ago from "server 2".
Once again: Thank you for your rapid answer!!!!! :D :D :D :D :D
Best,
SW
Sören Wallin
Sweden
