1.8.2 – wrong color label jxl file
Kadet
Post by Kadet »
Win 11
In a few folders with a lot of files mixed type I have issue with the color label of the jxl file.
First, or few first file, have correct color label, but next have default color.
Re: 1.8.2 – wrong color label jxl file
please send the "[Appearance]" of your xnview.ini
Kadet
Post by Kadet »
[Appearance]
useLabelSpacing=false
labelAlign=1
labelFont=@Variant(\0\0\0@\0\0\0\x1c\0M\0S\0 \0S\0h\0\x65\0l\0l\0 \0\x44\0l\0g\0 \0\x32@ MHs\xec\xad\xe3\xff\xff\xff\xff\x5\x1\0\x32\x10)
overlayIcons=65023
itemSpacing=4
useShadow=false
borderSize=1
borderColor=249 245 228
useThumbBackColor=true
thumbBackColor=244 244 244
thumbBorderSize=0
thumbBorderColor=244 207 0
thumbPadding=2
customLabel-1={EXIF:Focal Length}mm f/{EXIF:F-Number} {EXIF:Exposure Time}s {EXIF:ISO Value}iso
customLabel-2={Width}x{Height} - {Size KB}
customLabel-3=
customLabel-4=
customLabel-5=
defaultLabelColor=0 0 0
defaultLabelBColor=241 226 226
thumbLabels="1 55 "
formatColor-0="[jpeg],243 236 156,0 0 0"
formatColor-1="[gif],220 235 220,0 0 0"
formatColor-2="[png],86 128 176,250 250 250"
formatColor-3="[bmp],227 227 255,0 0 0"
formatColor-4="[tiff],192 197 235,0 0 0"
formatColor-5="[tga],230 255 255,0 0 0"
formatColor-6="[iff],247 235 235,0 0 0"
formatColor-7="[sgi],247 237 242,0 0 0"
formatColor-8="[pcx],235 230 230,0 0 0"
formatColor-9="[psd],255 255 227,0 0 0"
formatColor-10="[pcd],235 215 235,0 0 0"
formatColor-11="[psp],237 208 163,0 0 0"
formatColor-12="[pict],202 202 255,0 0 0"
formatColor-13="[xpm],242 227 227,0 0 0"
formatColor-14="[xbm],216 216 216,0 0 0"
formatColor-15="[pbm],191 191 182,0 0 0"
formatColor-16="[pgm],207 207 197,0 0 0"
formatColor-17="[ppm],235 225 159,0 0 0"
formatColor-18="[ras],255 255 227,0 0 0"
formatColor-19="[wmf],187 187 187,0 0 0"
formatColor-20="[emf],212 212 212,0 0 0"
formatColor-21="[ico],217 247 227,0 0 0"
formatColor-22="[cur],217 247 227,0 0 0"
formatColor-23="[ani],217 247 227,0 0 0"
formatColor-24="[fpx],229 255 255,0 0 0"
formatColor-25="[jp2],237 237 202,0 0 0"
useFormatColor=true
selectedColor=10 36 106
formatColor-26="[jpegxl],248 216 68,0 0 0"
formatColor-27="xcf,48 54 32,252 243 197"
formatColor-28="avif,172 255 191,40 34 17"
formatColor-29="[webp],255 187 155,0 0 0"
i can't reproduce, please send the jxl files
Kadet
Post by Kadet »
It is not easy to reproduce this error, it requires a lot of files. I have prepared a package for download that causes this error for me.
And this is not an error in the specific file. Copying a small portion of the files, that were displaying incorrectly color, to a new location are fine in the new location.
https://drive.google.com/file/d/1biOU2- ... sp=sharing
Kadet wrote: Wed Oct 30, 2024 4:54 pm And this is not an error in the specific file. Copying a small portion of the files, that were displaying incorrectly color, to a new location are fine in the new location.
If you don't have this problem in a new folder, there is a problem with catalog. Select the files and 'View>Update catalog from files'
Kadet
Post by Kadet »
xnview wrote: Tue Nov 05, 2024 9:36 am
Problem is in all folders with a lot of files. When I copy a small portion, colors are OK, but when I add few hundreds files to this folder, colors are wrong.
Your tip don't repair problem.
i've tried with your samples, make 3 copies and no problem with jxl...
Kadet
Post by Kadet »
And what can I say in such a situation? This certainly makes it difficult to analyze the situation, but the facts are that there is a problem, as I showed in the image. I hope you will find this strange issue in the code.
Kadet
Post by Kadet »
After installing version 1.8.3 and rebuilding the thumbnail database, the problem does not occur. We can forget about it for now.
