UNC Path / Network Share folder tree browse delay
CarlosGT
Post by CarlosGT »
Some post ago for Classic and now on MP with same behaviour.
Environment: Synology NAS with Active Directory. Computers with Windows 7 -10 Pro. Latest version XnView and full updated. Gigabit LAN wired. 3 devices over the network (Server + 3 PC).
INI modified to inlcude ExpandUNC=True on [%General] tab.
I can browse on windows all the folders and network shared folder instantly. If i click over a network photo on the windows explorer, Xnview MP open instantly. No problem here. I can run the mouse wheel and see full screen photos BUT, when double click to go to the Xnview Navigator there are 2 freezes:
1st.- Show "Desktop icon" No folders
2nd.- Show "Not responding"
After 30 seconds, navigator folder pane shows the network tree and i can browse and work normally (Note: My computer "Liberty" appears twice )
Same behaviour on Classic.
Tried to remove folders thumbs as read on some post, with no success.
Thank you for your help.
Carlos
Re: UNC Path / Network Share folder tree browse delay
please change in xnview.ini debug=2, and check the logs window where you have delay?
CarlosGT
Post by CarlosGT »
Hi Pierre,
Please, let me know where insert the "debug=2" line on the .ini file. I guess this create a log file on the Xnview folder.
Thank you for your support.
Carlos
CarlosGT wrote: Fri Nov 22, 2024 7:20 am where insert the "debug=2" line on the .ini file
its already there (equal 0 by default), change it to 2
[Start]
debug=0
CarlosGT
Post by CarlosGT »
On Classic .ini there is no [Start] label (neither debug=0, line). Inserted at the top of the .ini file with no effect.
On XnviewMP that label exist. Have changed to "2" and appears on background a debug screen. I can copy/paste this text to send it to Pierre.
Thank you.
Carlos
