How to view Kodak photo PCD files at full size?
MadHatter99
Post by MadHatter99 »
I just downloaded XnView to get access to photos on an old Kodak photo CD with the images stored as .PCD files.
I can open the files, but only see thumbnails 512 x 768 pixels.
The info bar says the photos are 3072 x 2048 but I can only export them at the small size.
How can I get full sized JPEGs?
Re: How to view Kodak photo PCD files at full size?
Sorry but only possible with x32 Classic version (there is an old plugin)
MadHatter99
Is there any program that will do this?
MadHatter99 wrote: Wed Nov 13, 2024 9:49 am Is there any program that will do this?
If you are using Windows you can install XnView Classic, which is 32-bit software, for viewing PCD files at full size, and continue to use XnView MP for everything else... :)
MadHatter99
Thanks, but anything for Mac?
