How to make star ratings icon bigger and change position
GeoFire
Post by GeoFire »
Hi, I would like to know if there's any way to increase the size of the star rating metadata and also change it's position from right to left
As you can see in the image, I would like that little almost unnoticeable star to be bigger if it could be like the size of that green star I put in the image that would be perfect and I also would like to put it in the left side of the screen.
I don't have any problem to change some files, download a plugin or any other thing if it's needed.
Thanks for reading.
Re: How to make star ratings icon bigger and change position
sorry but currently no way
GeoFire
Post by GeoFire »
xnview wrote: Wed Nov 13, 2024 3:19 pm sorry but currently no way
Oh ok, no problem. Thanks for your answer.
stealthyelephant
Post by stealthyelephant »
The option to set star position underneath preview images would make it more obvious. Also under every thumbnail would be great. #featurerequest
