There are abnormal symptoms starting from version 1.80.
If you adjust the brightness, contrast, brightness, saturation, etc. with the enhanced color, the range of change is very different.
In the case of version 1.80, about 30 changes are required, and in later versions, about 70 to 80 changes are required to become similar.
In versions 1.81, 1.82, and 1.83 released after version 1.80, adjustments such as brightness, contrast, value, and saturation work differently than before version 1.80.
We often do light corrections with enhanced colors, but please check why it works differently after version 1.80 and make corrections
There are strange symptoms starting from version 1.80.
dosiper
Re: There are strange symptoms starting from version 1.80.
why do you need now about 80 changes?dosiper wrote: Thu Nov 14, 2024 6:03 am In versions 1.81, 1.82, and 1.83 released after version 1.80, adjustments such as brightness, contrast, value, and saturation work differently than before version 1.80.
