As a new user of the program, I converted around 15 image files to Jpegs today. After doing so, I discovered that File Explorer will not place them in alphabetical order. No matter how many times I click to alphabetically place files in a large image folder I use, all the files I converted today using XnConvert stay together no matter what they are named.
This has never happened before - can you help?
Trouble with Windows File Explorer after conversion
BDinger
Re: Trouble with Windows File Explorer after conversion
when you change the sort order in Windows explorer, the sort doesn't change?
