I am using the latest version of XnView MP on a 4k resolution (might be a reason?).
As you can see from the attached screenshot, the navigation bar is way too big while the quick filter is tiny.
I use the quick filter feature a lot, and sometimes part of the text is cut off because the space is just too small.
Is there a way to adjust the size of those bars and move things around? or at least just increase the width of the quick filter?
Thanks.
Navigation bar too big, quick filter too small
Ravanelli
Re: Navigation bar too big, quick filter too small
Path field need more space than quick filter. Currently there is no way to increase...
Ravanelli
Thanks.
Are there any plans to let users customize those bars/fields, and be able to move other elements around?
Ravanelli
Hello,xnview wrote: Sun Nov 24, 2024 2:08 pm Path field need more space than quick filter. Currently there is no way to increase...
Any update on this issue?
Can we at least make those fields 'draggable' or customizable?
For me as an example, I use the quick filter more than the path field because I have most of my images in a single folder tree.
I hope that you would consider adding this feature/option.
Thanks.
change layout in Settings>Browser>Toolbar
Ravanelli
Thank you for the suggestion, but I have tried this before (all 4 layouts);
and they all have the same issue (very narrow quick filter field).
Ravanelli
Should I look forwards to this? or should I just move on since it cannot be coded?xnview wrote: Sun Nov 24, 2024 2:08 pm Path field need more space than quick filter. Currently there is no way to increase...
Thanks
Ravanelli
HI,
is there a way we can edit the skin/theme to allow for more space in the quick filter field?
Thanks
Thanks
