rc1: save keys not work in panorama
marsh
Post by marsh »
<ctrl + s> <ctrl + shift +s> don't work when looking at panorama result.
XnView 1.82 <x>
OK here…
:) Hi B. !
- I cannot confirm, both shortcuts work perfectly here; I tested a creation, just at this moment, no problem.
- Under XP-Pro and with small images …
:mrgreen: KR
Xyzzy
Post by Xyzzy »
Confirmed here. I had to go to Browser tab and back to <Panorama> tab for these shortcuts to work.
X.
Re: rc1: save keys not work in panorama
marsh wrote:<ctrl + s> <ctrl + shift +s> don't work when looking at panorama result.
Confirmed. Right after creation of the Stripe of images, some things do not work properly. E.g. many shortcuts or zooming with mouse wheel.
Dreamer
Post by Dreamer »
Confirmed. Almost all shortcuts don't work (except F11, Enter).
marsh
Post by marsh »
I can get panorama keys to work (maybe this helps):
1. Tabs on.
2. Create panorama.
3. Keys work again if you switch tab to browser and back again to panorama.
Still OK---
—> marsh
:) Hello B. !
- These shortcuts work still OK here without your workaround under XP-Pro - XnView 1.82.2
:mrgreen: KR
Dreamer
Re: Still OK---
Post by Dreamer »
Clo wrote:—> marsh
:) Hello B. !
:mrgreen: KR
What shortcuts??
/, Ctrl+S, Ctrl+Shift+S, F... still don't work here.
These ones
—> Dreamer
:) Hello !
- Ctrl+ C and Ctrl+Alt+C copy the strip - Ctrl+Shift+V pastes it - Ctrl+S ¦Ctrl+Shift+S open the "Save as…" dialogue - F11 works here for full screen, no problem.
From the "View mode" >> Tools menu to create the strip.
:mrgreen: KR
I've just retried to reproduce the problem in 1.82.2 and found that the problem still persists.
@Clo: It might work on your system, but there's at least three people who experience the problem. There is a problem, right after creation of the image strip all shortcuts and mouse wheel will not work.
Scroll only...
—> Helmut
• Hi !
- Here under XP-Pro… I use the mouse-wheel to scroll the screen <—> Up¦Down only, and Does nothing for the middle-button (pressing the wheel) because I prefer to keep the 4-arrowed maker's cursor.
- Maybe the use of the wheel ¦ middle button for other purposes could cause your issue ?
:mrgreen: G.
Dreamer
Post by Dreamer »
helmut wrote:I've just retried to reproduce the problem in 1.82.2 and found that the problem still persists.
Not all shortcuts, some work good here, e.g. *, +, -, F11, Enter - and LMB double click, MMB, RMB+LMB.
But RMB+wheel doesn't work.
marsh
Post by marsh »
A new fix! RC1.
