Please separate the registry ProgIDs for WebP and AVIF. (Windows)
sazi
Post by sazi »
Hi! :D
*First of all, this problem may not be an XnView issue, but a Windows issue, or it may be due to my Windows PC environment.
I work with image formats WebP and AVIF a lot. The problem is that the icons are the same for both, making it difficult to tell them apart.
When I read the registry, both have the ProgID XnViewMP.image. If possible, please give WebP and AVIF different ProgIDs.
For example, XnViewMP.webp & XnViewMP.avif
That way, you can easily give different icons to the two image formats.
Kind regards.
Re: Please separate the registry ProgIDs for WebP and AVIF. (Windows)
i'll add the icon for WebP
sazi
Post by sazi »
:D :D :D :D :D :D :D :D :D :D
