Subject: 1.83.0: Metadata cannot delete complete and save without blank letter
mokati
Post by mokati »
XnView: MP 1.83.0 - 64-bit
OS: Windows 10 - 64-bit
Metadata cannot delete complete and save without blank-letter
Effect: Picture does not save Picture after deleting IPTC Data
1. comment a picture with IPTC text (see picture)
2. save
3. reopen the picuture and delete the comment (from 1. step) complete
4. save
5. reopen the picture => the comment (Metadata) is always existent and NOT removed !!!
workaround (i don't like it):
to remove a Metadata-Field it is nessesary to place a blank letter. :(
Re: Subject: 1.83.0: Metadata cannot delete complete and save without blank letter
Post by michel038 »
Are you sure you're making the right distinction between iptc and xmp?
Using "Edit IPTC" dialog > Options tab > Mode > IPTC only or IPTC and update XMP must be selected
or
Using "EDIT XMP" dialog > Options tab > Mode (Here, xmp is automatically selected )
With these settings, If I select 1 (one) jpg picture >
> Edit iptc > delete a field > Write > the IPTC field is deleted , no bug found
If you select more than ONE picture before opening "Edit IPTC" dialog, the problem is much more complicated...
If you want to delete the same field in multiple files, select the files and use
Metadata > Transfer > Add > Iptc caption (example of target field) >( let the content empty) > Apply
mokati
Post by mokati »
problem solved - no bug ;)
@michel038:
thanks for the good description.
The workaround with "Metadata transfer... " is working well;
it is what I was looking for
thanks, moka
