Dear user,
XnView Classic 2.52.0 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
https://download.xnview.com/XnView-win.exe (English Setup, Multi language)
https://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
https://download.xnview.com/XnShellEx.exe
https://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
https://download.xnview.com/XnShellEx64.exe
https://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 981917A1F1EF3F49A0E14E19630B880D722B2BC91EC9FE3B14796BEEB31E6099
XnView-win.zip: E31029A81045CF720C9D7B9ED5C6900BE3ACAAA1B230624E8990E36B5DFDC5F1
XnView-win-full.exe: 8DEA8343DE8D7E2178E94F1C92B058BF04E5ADFC6201C48416F09FA05A3F7B31
XnView-win-full.zip: 462450AA58975530F34CF034F58A3EAFC8D906D5EBBEE7FB5E48A52BBFA26024
XnView-win-small.exe: B928B0D210D48EDAE20F2EC08ACD1D0FA65DD66FAC0364405F47037E51E26173
XnView-win-small.zip: E148BCFC118FFCFDC7BF1039EAB8F05B741505A2136A4B4F0C77B6283BF708B3
____ 2.52.0 Changelog
* Old plugins removed from package
* NConvert: multipage and delete option
____ 2.51.7 Changelog
* GIF print - viewtopic.php?f=36&t=47348
* CVE - Thanks to Matteo Marini
____ 2.51.6 Changelog
* ICC
* TIFF CVE - Thanks To Eugene Lim
* CVE - Thanks to Junsoo Lee
* NConvert: Clear - viewtopic.php?f=57&t=46797
____ 2.51.5 Changelog
* HEIC not loaded
* LibWebP CVE
____ 2.51.4 Changelog
* TIFF crash
* NConvert: Bad output for TIFF LZW+Predict
* NConvert: Filelist - viewtopic.php?f=57&t=46034
____ 2.51.3 Changelog
* CVE - Thanks to Seyit Sigirci
* NConvert: HEIC (x64) - viewtopic.php?f=57&t=44026
* NConvert: TIFF 16 bits output with Predictor - viewtopic.php?f=57&t=44869
* NConvert: -keepcspace & big image - viewtopic.php?f=57&t=44789
____ 2.51.2 Changelog
* Export & extension missing - viewtopic.php?f=36&t=43430
* Argument in utf8 - viewtopic.php?f=36&t=44014
* Susie plugin - viewtopic.php?f=36&t=43887
* NConvert: longest/shortest & mm - viewtopic.php?f=57&t=44670
* NConvert: -recurse - viewtopic.php?f=57&t=43854
____ 2.51.1 Changelog
* CVE by Xu Peng from UCAS
* Minor fix
* NConvert x64 : JPEGXL & AVIF - viewtopic.php?f=57&t=43732
____ 2.51.0 Changelog
* WebP in Slideshow 'add folder' - viewtopic.php?f=36&t=42755
* QOI read support
* WebP 1.2.2
* NConvert: AVIF support - viewtopic.php?f=57&t=43096
* NConvert: Canvas resize & CMYK - viewtopic.php?f=57&t=42022
____ 2.50.4 Changelog
* TIFF crash
____ 2.50.3 Changelog
* Rotate dialog & show grid - viewtopic.php?f=36&t=42496
* Canvas resize on 1bit picture - viewtopic.php?f=36&t=39569
* FITS better support
* NConvert (Windows): Recurse support - viewtopic.php?f=57&t=42626
eg.: nconvert -o output/% folder
* NConvert: $DateModified - viewtopic.php?p=169286
* NConvert: Multipage output filename - viewtopic.php?f=57&t=42584
____ 2.50.2 Changelog
* Labels & tooltips can crash
* PNG crash
____ 2.50.1 Changelog
* Browser size not restored - viewtopic.php?f=36&t=42207
* Dialog always on Screen #1 - viewtopic.php?f=35&t=42147
* Context icon - viewtopic.php?f=34&t=42232
* NConvert: multiple -canvas & bgcolor
* NConvert: -jpegtrans - viewtopic.php?f=36&t=41826
* NConvert: -canvas longest 220mm - viewtopic.php?f=57&t=41812
* NConvert: jpegtrans exif & keepfiledate - viewtopic.php?f=57&t=42203
____ 2.50 Changelog
* APNG crash - viewtopic.php?f=36&t=41803
* JPEGXR RGB10
* CR2 orientation problem
* Ghostscript 9.54
* Recoil
* GEM vulnerability - Thanks to Michael Heinzl
* NConvert: -use_org_quality problem
* jpegtrans not written for NConvert - viewtopic.php?f=36&t=41826
* NConvert: -text_font name percent - viewtopic.php?f=57&t=41811
* NConvert: -canvas shortest/longest - viewtopic.php?f=57&t=41812
____ 2.49.5 Changelog
* Ghostscript detection
* TIFF - viewtopic.php?f=35&t=41136
* HEIF plugin - viewtopic.php?f=36&t=41104
* Old versions of ghostscript not recognized
* NConvert: -use_org_quality - viewtopic.php?f=57&t=41397
* NConvert: multiple text lines - viewtopic.php?f=57&t=41358
____ 2.49.4 Changelog
* Ghostscript 9.53.x
* GPS & file date - viewtopic.php?f=56&t=40971
* TIFF Security vulnerability (Thanks to Michael Heinzl)
* NConvert: -levels2 - viewtopic.php?f=57&t=40490
* NConvert: -resize supports cm/mm/inches
* NConvert: -autodeskew fixed
* NConvert: -noholder to disable %$ chars - viewtopic.php?f=57&t=40820
____ 2.49.3 Changelog
* Convert 16 to 256 colors - viewtopic.php?f=36&t=39421
* Disable ESC to close tabs - viewtopic.php?f=35&t=17078
[General] EscToCloseView=0
* Select file from search results & switching mode - viewtopic.php?f=34&t=40063
* Title empty when recurse - viewtopic.php?f=36&t=39979
* Resize - viewtopic.php?f=35&t=40248
* Slideshow: Order of files - viewtopic.php?f=56&t=40087
* Fortis Mag fix
* NConvert: -wmsize watermark percent size - viewtopic.php?f=57&t=38754
* NConvert: canvas size in inches/cm/mm - viewtopic.php?f=57&t=39361
* NConvert: replace_color - viewtopic.php?f=57&t=39769
* NConvert: -temperature added
____ 2.49.2 Changelog
* Problem with Ghostscript 9.50
* PDF font problem - viewtopic.php?f=36&t=39662
* CR3 - viewtopic.php?f=35&t=39478
* .sld must use 'Recurse' setting - viewtopic.php?f=35&t=39330
* GIF loop - viewtopic.php?f=36&t=31689
* PAM CMYK
____ 2.49.1 Changelog
* TIFF 16bits greyscale
____ 2.49 Changelog
* SQLite 3.29.0
* NConvert: greater_than/less_than condition - viewtopic.php?f=57&t=39147
* PSD: Error when writing metadata - viewtopic.php?f=57&t=39137
* Export - Problem with RGBA - viewtopic.php?f=36&t=39044
* Capture - viewtopic.php?f=36&t=38934
* Left/Right F11 to open fullscreen on Left/Right monitor
* Create multi file & folder with '.' - viewtopic.php?f=36&t=39008
* # to comment line in .sld file
* Multipage create: Check if output filename exists
* Slideshow crash when using animated GIF - viewtopic.php?f=36&t=38902
* XIM format import added
* Change timestamp must not use 12h format - viewtopic.php?f=36&t=38702
* GIF not played correctly in Slideshow - viewtopic.php?f=34&t=38303
* CVE - https://github.com/apriorit/pentesting/ ... ugs/xnview
* NConvert: -unsharp
* NConvert: -exposure - viewtopic.php?f=57&t=39136
* NConvert: -colorize h l s
* NConvert: Remove EXIF orientation -exif_rotation - viewtopic.php?f=57&t=38648
* [Rename]/TemplateStart, position of number in template - viewtopic.php?f=34&t=38568
* CVE-2019-12151
* ShellEx: 'Convert...' & input fields
