Hi there,
is there any way to disable the automatic check for updates via Group Policy, i.e. a registry key that I could delete or alter?
Thanks in advance!
toco
Disable Update Check via GPO / Group Policy Settings?
tocophonic
Re: Disable Update Check via GPO / Group Policy Settings?
Tools > Settings... > General has an option to disable checks for updates, if that would meet your need, possibly not?tocophonic wrote: Tue Nov 26, 2024 9:39 pm is there any way to disable the automatic check for updates via Group Policy, i.e. a registry key that I could delete or alter?
tocophonic
Yeah, but I want to distribute that setting to 5000 computers, so I am searching for something that I can deploy via GPO.
tocophonic
Not a 100% sure yet, but I think I found the solution:
I can deploy the xnview.ini with the checkFreq=0 value!
