Application opening in full screen
HGNart
I lost my Windows Elements in XnView MP. Application is opening in full screen mode, hiding Windows task bar and Windows Minimize, Maximize and Close button on right upper corner. Find no way to change this.
Re: Application opening in full screen
If you hit F11 does it take you out of full screen?
HGNart
Sorry for late Answer. See my attached Screenshots after and before F11
Assuming your issue is simply the application opening in full screen due to the way it is configured, you should be able to change that at Tools > Setting... > General > Strartup...
Why that was ever the default is a mystery, but I believe there has recently been at least talk of changing the default setting.
HGNart
No success but I made a small screen shot. This open as normal. I reduced this window, closed the application and it starts perfect.
Problem solved
Problem solved
I don't understand, but in any case you are able using the above setting to configure XnView MP to open in fullscreen mode or with the file browser or the editor (viewer) open.
