Saving image from clipboard
bepi caon
Post by bepi caon »
I copy a screen image with Win 11. Paste through "Edit" and "Modify" in XnView and "Copy clipboard windows". than "Save." It takes impossible times (many minutes) or does not complete the operation. By completing the operation with "Task management" you will find the saved file.
Thanks end good live. (Sorry, I don't speak English at all)
Re: Saving image from clipboard
do you save it in an empty folder?
