1.8.3 - "Tools - Join images" and status bar
Peter2
When I use "Tools - Join images" I get this information in status bar:
Re: 1.8.3 - "Tools - Join images" and status bar
i can't reproduce, how many files do you use?
Peter2
I tried again - it seem to appear in a special configuration:
- open a TIFF. This displays the pages and the size in cm
- start the command "Tools - Join"
- add files with the button (I have 9 images, each 4128x2322 pixel, joined as mosaik 3 x3, distance 50 px
- start the command
Then I get again these values ..
- start the command
i can't reproduce, perhaps you can send me the file used
Peter2
I just copied this file 9 times and could reproduce it. It seem to mess up the pages of a TIF file and the number of the files in the current directory.
But if you cannot find it there is no problem - it`s a very small issue ..
