Wishlist: Favorite folder, Previewer on/off, XCF support,...
MRRhum
Post by MRRhum »
I've been using XnView for some time, for which I thank you. There's just a few features that I would like to see added, most of which seem fairly simple. Here's my list:
  • *Favorites in opening view. It would be useful to be able go to a favorite folder instead of a recently-used folder when first opening the program.
    *Toolbar button to turn previewer on and off. I find myself switching the preview pane on and off a lot, and it's a bit awkward to use Ctrl-Shift P each time.
    *Shift-Enter (or Ctrl-Enter) on an image launches it in alternate viewer.
    *Thumbnails for GIMP xcf files.
Thanks.
Re: Wishlist: Favorite folder, Previewer on/off, XCF support
Thanks for your input, Mr. Rhum. Some comments:
MRRhum wrote: *Favorites in opening view. It would be useful to be able go to a favorite folder instead of a recently-used folder when first opening the program.
In the options, category "Browser" you can select the option "Specified" and specify the directory you want to view, first. Is this what you've been looking for?
MRRhum wrote:*Toolbar button to turn previewer on and off. I find myself switching the preview pane on and off a lot, and it's a bit awkward to use Ctrl-Shift P each time.
A good idea for the toolbar. In general, there should be more functions available in the toolbar. Perhaps not by default, but choosable in the options.
MRRhum wrote:*Shift-Enter (or Ctrl-Enter) on an image launches it in alternate viewer.
Good idea. Personally I'd prefer Ctrl+Enter.
MRRhum wrote:*Thumbnails for GIMP xcf files.
I don't have GIMP files, but GIMP and XnView might be a good combinations/partners on both Windows and Un?x platforms.
Post by Guest »
Helmut--
Thank you for your reply. My reponses to some of your remarks are below.
helmut wrote:Thanks for your input, Mr. Rhum. Some comments:
No, I had in mind something like the dropdown favorites list at the top left of the browser window.
On further reflection, I agree.
Indeed they would. I have been using them together on Windows for quite some time.
MRRhum
Post by MRRhum »
BTW, that was me responding above. I forgot to sign in first. :?
--Michael
