I used to use the buttons to dump a folder and then get rid of anything that doesn't have a filtered part of the name in the top right. I re-installed my computer and I can't find this button on the new version of the app?
Is there a new way of doing this now? If not why was this removed?
'Remove Unfiltered' Button Missing?
Re: 'Remove Unfiltered' Button Missing?
you can always filter the list of files
D3K17
Do you mean in the app or by third party means? If so in the app, how is it done?
I ended up finding version 1.85 in the downloads list and using it as I believe this was one of the last versions that had these buttons.
i means text field 'quick filter'
D3K17
Oh yes, but what I mean is if I have a folder (and its sub-folders) of images I dragged and dropped and I only want to apply the conversion on the images that do not have '_ORM' in the name, how can I do that?
This problem is supposed to be fixed in XnView MP 1.8.4. Please check and confirm the bug fix here.
