Error in final statistics
Xn User
Post by Xn User »
Hi )
I'm convert 97068 files with a common oven 109,3 GB , however XnConvert report what have diffirence 1.13 GiB , at the same time real difference is in size 23% , why so ?
Log XnConvert:
Input files: 97068
Extracted pages: 97068
New files: 97068
Total input file size: 1.36 GiB
Total output file size: 1.13 GiB
File size ratio: -16%
Total Duration: 6 hour(s) and 53 minute(s)
Finished at: 11.12.2024 1:07"
Re: Error in final statistics
Your issue is that the output file size should be the same as the input file size?
If so, and the output file format is the same as the input file format, has the compression level used possibly changed?
If necessary, you can view the parameters of example input and output files using XnView MP's Image > Properties... display.
Or you could post an example input file and the output file produced for that file.
Xn User
Post by Xn User »
No , problem in other , if XnConvert do transcoding very very very large folders about 100 GB and very very very more files , so XnConvert do calculate correctly , but in final it turns out a mistake , because XnConvert loss log and do calculate summ somehow differently also , sometimes absent result statistics ) I think , that it will be better if this statistics are not displayed at all
are you able to reproduce on 2 files?
Xn User
Post by Xn User »
I try do this , but If I recompress more files 250K and more , final statistic easy not displayd , because I can not replay this , but I recive ths once
Xn User
Post by Xn User »
Example errors , as can see files 1200 , but in report
Input files: 1200
Extracted pages: 1200
New files: 1199
why ? Where he was gone one file ?
And also absent calculate statistics ? Not report how much size will changed )
If it is important I'm use 12 threads for transcoding
At the same time in folder realy 1200 files after transcoding , but in statistics have error )
could you send me a sample file used? so 12 threads, and which settings for ouput?
Xn User
Post by Xn User »
Any big files convert from JPEG2000 to WEBP
which output settings? Actions?
Xn User
Post by Xn User »
Were 12 threads , WEBP Lossless Compression method 5 File stength 100 Filter sharpness 7 , Save preset Photo ) but now I can not replay this bug , I do not known why
