The View screen no longer shows the Info data. The data does appear on the Full Screen view.
MacOS Sequoia 15.1.1
View screen missing Info data
DTD
Re: View screen missing Info data
even if you press I key?
DTD
Pierre,
Thank you for the quick response. Yes the I key does make the info data appear on the view screen. But in previous versions of XnViewMP the data would appear without pressing the I key. Is there a way to default the info data on the View screen like the Full Screen?
Regards
DTD
Regards
DTD
you open fullscreen (from browser or image tab?), press 'I' key to show info, close fullscreen, open another image in fullscreen and 'image info' is not here?
DTD
I use the View screen not the Full screen. But now the info data is appearing on the View screen. Must have been A.B. User. Apologies and thanks for your help
ABuser
ABuser
