I use this for sorting my photography and its great. I just cleaned up over 2tb of photos with a ranking system. I have now backed it up to a second SSD however I want to back up the rankings as well.
I use, categories, color labels, and set ratings. I have seen a post about how to copy that data but can no longer find it. I would like to copy to file with all the rankings onto my backup hard drive so this organization is not lost.
I am using a macbook pro and would like to find the file so I can make sure this information is copied for the photos. When I access the backup drive none of them have the rankings. The backup drive file and folder names are all the exact same as the original.
Thank you
Copying Photo Flags and Rankings
Re: Copying Photo Flags and Rankings
so it seems that you use only the catalog to store rating?
in this case you need to backup *.db
