I have installed XNview mp on another computer, is it possible that I will also get all the changes I made on my other computer on my new one?
I changed the settings, screen info, full screen info.
Install XNview mp on another computer
Re: Install XNview mp on another computer
Locate your original .ini file using Tools > Settings... > Integration > Paths and save a copy, then replace the .ini file on the other computer with a copy of that file. Best to retain the original file temporarily in case of any misstep.
If needed, follow a similar procedure for any database etc. files that you also wish to transfer.
