Remove noise
jakra1953
Remove noise
Post by jakra1953 »
Can noise be removed in xnview mp?
Re: Remove noise
jakra1953 wrote: Wed Dec 18, 2024 3:18 pm Can noise be removed in xnview mp?
There are various filters in Effect > Effect... that you could look at, I am not immediately aware of any other options.
Re: Remove noise
I see that there is near the end of the list of filters a Reduce noise filter... :D
jakra1953
Re: Remove noise
Post by jakra1953 »
That filter is not working
Re: Remove noise
jakra1953 wrote: Sat Dec 21, 2024 3:08 pm That filter is not working
I've never used it myself, as indicated I didn't even know that it was listed until you posted!
Are you saying that when selected there is absolutely no discernible effect, which might possibly relate to the characteristics of the image to which it was applied, or that XnView MP crashes, for example?
Kadet
Re: Remove noise
Post by Kadet »
Use G'MIC plug in - newsgroup.xnview.com/viewtopic.php?f=82&t=41526
Or use Topaz Lab software.
