DivX and XviD
All non-XnView related: softwares, formats, imaging, photography...
ckit
DivX and XviD
Post by ckit »
DivX Create (Trial) and DivX Play (Freeware):
Homepage: http://www.divx.com/
ckit
XviD 1.1.0 Final
Post by ckit »
XviD 1.1 Final - Opensource Freeware:
Changelog:
- {core}: Field interlaced decoding.
- {dshow}: Additional fourcc support.
- {vfw}: Small updates.
Finally, the 1.1.0-release is ready for prime-time!
Only small fixes and changes were done compared to beta 2, but you might like the (a little bit) overhauled vfw-front-end.
Homepage:
http://www.koepi.org/ and http://www.xvid.org/
ckit
Post by ckit »
DivX Create 6.2 (Trial) and DivX Play 6.2 (Freeware):
New:
* A new encoder preset option allows you to quickly configure the encoder based upon your preference for encoding speed and video quality
* The DivX community codec replaces the current free version of DivX, offering a wider range of performance and quality options for free through encoder presets
* Multithreaded resize filters have been added for improved performance on all HyperThreaded (HT), dual CPU (SMP) and dual core processors
* A new "Enhanced multithreading" option capable of increasing encoding rate depending on system configuration and encoding environment
* A new "Enhance texture" psychovisual enhancement method that improves picture details around keyframes and reduces the appearance of stray blocks under fast motion when encoding at lower bitrates
* MMX optimizations for the MPEG quantization method
* The DivX decoder can anonymously check for updates to the DivX codec, ensuring you are always notified of newer versions. For more information, and to enable notifications for future beta releases, click here.
Fixed:
* Fixed a problem where multiple instances of the feedback window would cause the encoder to fail
* Fixed a problem where very old DivX 5.0 content might not be decoded correctly
* The encoder GUI now adapts to screen resolutions of 800x600 or lower
Changed:
* Bitrate modulation for multipass nth pass encoding is now preset at an optimal value for quality, and this option removed from the user interface.
* The DivX Pro 6 month trial has been replaced by a 15 day trial, which can be started from the DivX encoder GUI, rather than during installation. This is because a much wider range of features are now available for free in the community codec. Previously installed 6 month trials will be honored.
ckit
DivX and PX Hell
Post by ckit »
Starting at DivX v6.1 and higher includes the "evil" prassi px burning engine which can play hell with your optical drives!
Here's how to fix the BS...
Open RegEdit at this key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
remove the LowerFilters = Pxhelp20
Now reboot!
Not necessary but you can also remove all the PX*.* files from %windir%\system32 folder too.
PS. You can avoid the PX burning engine being installed by NOT installing the DivX Player and DivX Web Player!
ckit
Post by ckit »
DivX Create 6.2.5.17 (Trial) and DivX Play 6.2.5.17 (Freeware):
Here are some of the highlights:
* A new "Sharpening" post-processing feature that enhances texture and sharpens any DivX 3, 4, 5 or 6 video
* Optimizations for decoding and post-processing
* Performance enhancements for post-processing on HT, SMP, and dual core processors
Download: http://www.divx.com/divx/windows/codec/features/
ckit
Post by ckit »
DivX v6.3 has been Released.
martin10018
Re: DivX and PX Hell
Post by martin10018 »
ckit wrote:Starting at DivX v6.1 and higher includes the "evil" prassi px burning engine which can play hell with your optical drives!
Now reboot!
Thanks for this tip! Why does a video player install CD burning files?
ckit
Post by ckit »
XviD-1.1.2 final build.
Changelog:
Xvid-1.1.2-01112006:
- {core}: Fixed bug when frame-drop (N-VOP) feature is used in combination with packed B-frames
- {core}: Fixed potential crash on AMD64/EMT64 architecture.
- {core}: Fix for visual_object_verid vs. video_object_layer_verid problem.
- {core}: Ensure intervening bytes are preserved in BitstreamInit()
- {vfw}: Prevent segfault when encoding application calls compress_end with NULL codec context
- {vfw}: Profile definitions updates.
Xvid 1.1.2 fixes also a bug with unaligned bitstream buffers still present in Xvid 1.1.1.
Download: http://www.koepi.org/XviD-1.1.2-01112006.exe
Homepage: http://www.koepi.org/
ckit
Post by ckit »
DivX v6.4.1 has been Released (personally I now use FFDShow for everything)
Olivier_G
Post by Olivier_G »
ckit wrote:personally I now use FFDShow for everything
Wowowot??? :shock: ...Do you mean encoding too? (like with Virtualdub, for example)
Olivier
ckit
Post by ckit »
No, if I do any encoding I'll use XviD 1.1.2.
Olivier_G
Post by Olivier_G »
ckit wrote:No, if I do any encoding I'll use XviD 1.1.2.
Ahhhh... Thanks for confirming. I thought one moment I was an old and outdated geek-wanabee... :mrgreen:
By the way, did you try X264? (I was impressed by the compression efficiency. Hardware support should improve steadily too...)
Olivier
foxyshadis
Post by foxyshadis »
Hardware support is already coming fast, but it's often known as Bluray and HD-DVD. =p
(You can encode in ffdshow, but even though I maintain the project, I would never recommend it except as a last resort. Now x264, I can't recommend enough...)
ckit
Post by ckit »
X264 is CLI only and therefore complete and utter garbage.
Notice that support for encoding X264 was removed from FFDShow too, says alot I think.
XviD 1.2 (VFW) is the future although I'll stick with v1.1.2 for now.
foxyshadis
If you really have to get your vfw love on: current vfw x264.
The only reason we chose to remove x264 from ffdshow was because it was getting very outdated (about a hundred revs behind), it wasn't going to be easy to update (having been customized to fit in), and because a vfw version already existed (although it wasn't up-to-date at the time). The discussion was here.
No ffdshow developer looks down on x264 as a project or codec.
