I used "Create - File Listing" and got for ..
- CSV the separator ":" and for
- TXT a tab as separator
Is this intended?
Create - File Listing: CSV with
Peter2
Re: Create - File Listing: CSV with
These settings are the default settings, yes.
But there are some tips to get other separators :
- Use TXT Format, and set all metadata in the same field (to prevent the use of tabs) , and build it with your own separators.
-If you want XnViewMP to be able to "Open" this file list, use this syntax for example, in a single field :
"{Directory}{Filename With Ext}";{iptc:keywords};{iptc:city}
Catalogage avec XnviewMP :
