How to change Theme (color scheme) starting from "bright"
Daimonicon
Post by Daimonicon »
I would like to change the font size for some areas. But I want to keep the color scheme “light” with a much sharper font and start from that. Manually starting from dark is yes, is there a style file that serves light as a base so that I can adjust the font sizes here?
Re: How to change Theme (color scheme) starting from "bright"
if you use light or dark theme, there is no way to change font size
Daimonicon
xnview wrote: Tue Jan 14, 2025 8:27 am if you use light or dark theme, there is no way to change font size
That's a pity the font display with “light” is optimally sharp for me, but thanks anyway.
