Program workload (busy) indicator
Daimonicon
Post by Daimonicon »
would it be possible to make it visible when the program is fully busy or generally busy ? Progress indicator in the status bar or a cursor busy animation ? Maybe optional as not everyone needs it, but with many single images this would be very helpful.
Peter2
Re: Program workload (busy) indicator
Post by Peter2 »
In which situation would you need this? Opening? While modifying? Creating dozens of thumbnails?
Daimonicon
Peter2 wrote: Mon Jan 13, 2025 3:58 pm In which situation would you need this? Opening? While modifying? Creating dozens of thumbnails?
While metadata of more than 100 files are written or more e.g.
with 'Edit XMP'?
