Unable to addtext In Tiff File
Amitsinghkohli
Post by Amitsinghkohli »
Hi 2 all,
I worte a code to add text on tiff file, but
When I am trying to Add Text at Bottum left corner of tiff file,
But it does not works
But when i Use same code but change the file type(jpg) it works fine,
i try both Version Activex/VbModule but problem is same
Please tell me the way to add text on tiff file
Thanks
Amit Singh Kohli
Re: Unable to addtext In Tiff File
Amitsinghkohli wrote:Hi 2 all,
Thanks
Amit Singh Kohli
Your tiff is a binary picture or RGB?
Post by Guest »
Thanks
Amit Singh Kohli
forgive my poor english first..
I have ever met the same problem,when i Merge a .jpg file with a .tif file.
the .tif file was in index color mode,but i changed it to RGB mode with photoshop ,it works perfectly.
so ,i suggest you to change the tif file's color mode to RGB mode with photoshop.
