Rotate buttons/Automatic orientation/Recurse Folders
fecund
Post by fecund »
I wish for:
- All lossless jpeg transformations to use the "optimize" flag which makes for slightly smaller files without changing any pixels.
- A "unified rotate" that applies the lossless rotate to JPEGs, and does a regular rotate & save for other files.
- Rotate/flip buttons in the browser toolbar
- Buttons for the individual (unified!) lossless transformations, so I can rotate with a single click on the browser toolbar or image view toolbar.
- Rotating the internal thumnails when rotating an image that has them.
- A "smart rotate" that checks for an orientation flag. If it finds a flag and it says the picture is not upright, rotate picture upright and adjust flag.
- Clicking on a folder and applying an image transform to transform all items in that folder and subfolders, recursively. Basically I want to losslessly smart rotate folders of folders of jpegs all at once, but to be fair, all the operations from "Image" & "Filter" that make sense should be available.
- Attatching functions to "hotkeys" so I could, say, invert an image by hitting F4.
- Using a hotkey to apply a transformation to an image in the browser view when the cursor is hovering over an image, no click necessary. This would save time (and can make rotating images as effecient as Rota)
I'm willing to donate a little $$ to make some of these happen, probably not what the time to do it is worth but still an incentive! If you want to discuss use a private message.
Re: Rotate buttons/Automatic orientation/Recurse Folders
fecund wrote:I wish for:
all lossless jpeg transformations to use the "optimize" flag which makes for slightly smaller files without changing any pixels.
a "unified rotate" that applies the lossless rotate to JPEGs, and does a regular rotate & save for other files.
Thank you for your good suggestions and valuable input! Think JPG rotation and orientation are very important issues when working with digital cameras, so it's important that XnView improves in this area and supports these features well.
