XnviewMP 1.8.4 64-bit windows. Lib format 7.201
The "swap selection width and height" function on the crop toolbar (<>) doesn't swap height and width of the selected area anymore.
If I select 1.33 (4:3) for the aspect ratio then draw an area to select, then press the <> button, the width and height are not swapped. The numbers in the fields on the toolbar swap but the selected area's width and height are not swapped. If the original image is landscape the selected area remains as landscape, and gets smaller with each pressing of <>. If the original image is portrait the selected area remains as portrait and the size gets bigger with each press of <>.
Crop height and width swap
Re: Crop height and width swap
fhunor
I am experiencing the exact same problem
