Hi )
Program will crashed if select images and press Shift+C
Version 1.8.5 https://www.mediafire.com/file/bbyd72do ... c.avi/file
In release version 1.8.4.0 this bug absent
Pressing Shift+C causes crash in version XnView MP 1.8.5.0
Xn User
Re: Pressing Ctrl+C causes crash in version XnView MP 1.8.5.0
i can't reproduce, which format do you copy?
Xn User
Any , simply select WEBP or any other format and press Shift+C and recive crash
Please sorry I made a mistake in the topic , not CTRL+C , need to press Shift+C
you means when selecting 2 files and Tools>Compare
Xn User
Re: Pressing Shift+C causes crash in version XnView MP 1.8.5.0
Yes , with select two and more files and tools -> compare
This problem is supposed to be fixed in XnView MP 1.8.6. Please check and confirm the bug fix here.
