Update Installed to Wrong Folder
PRORACING
Post by PRORACING »
Hi everyone,
The program prompted me to update, so I went ahead with it. However, the installation was done in a different folder than the existing one. As a result, instead of an actual update, a completely new version was installed. Now I have two versions running in parallel.
I assume this is some kind of bug and not the intended behavior — just sharing for awareness.
The frustrating part is that I want to use the new version, but of course, my settings aren’t there, so I have to configure everything from scratch. :-(
Cheers.
Re: Update Installed to Wrong Folder
PRORACING wrote: Mon Feb 10, 2025 12:06 pm The program prompted me to update, so I went ahead with it. However, the installation was done in a different folder than the existing one. As a result, instead of an actual update, a completely new version was installed. Now I have two versions running in parallel.
In Windows?
You should be able to find the location of the version you are running from Tools > Settings... > Integration -- Paths... :D
VictorVG
Post by VictorVG »
Also try check this key use favorite Registry editor:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\XnView MP (x64)_is1]
"Inno Setup: Setup Version"=""
"Inno Setup: App Path"=""
"InstallLocation"=""
"Inno Setup: Icon Group"=""
then up to Windows 7 Inno Setup write's uninstall data here.
Xeon E5 2697v2/C602/128 GB PC3-14900L Quad Channel/GTX 1660 Ti/9 Tb HDD
Xeon E5-2697v2/C602J/128 Gb PC3-14900L Quad Channel/GTX 1660 Ti/7Tb HDD
