Bug if rotate image and next press esc
Xn User
Post by Xn User »
Hi )
Bug if rotate image and next press esc : https://www.mediafire.com/file/ui9xy8in ... e.avi/file if I open image in XnView MP , and next after rotate imae press esc so XnView MP close image and not open folder in which was be file , Instead simply window which not react on press enter , but if I open image , application show image with info , even if this information not was requested
Re: Bug if rotate image and next press esc
Please describe the steps to reproduce, not easy to see on your video
Xn User
Post by Xn User »
xnview wrote: Fri Feb 14, 2025 2:59 pm Please describe the steps to reproduce, not easy to see on your video
I all describe ) I open image , any image in any format ) , next when I see image , I press esc , and next try press enter , after this I can not open folder with image , but if I open next Image , I see information on left top angle , now , If I press enter , I can browse folder with images , but each image will be open with information on left top angle
please send me the xnview.ini?
Xn User
Post by Xn User »
i've tried with your settings.
I open image, next image, press esc
Here you have the empty window with no opened image
'and next try press enter' => you can't go to browser, there is no current path
Xn User
Post by Xn User »
Yes , this and problem , I think what if do so , have meaning requesting path with opened image and if do press esc , open folder where was be image ) I want sayd , what need do same reaction on press enter and on press esc )
Xn User
Post by Xn User »
If who think what this bug also as and I , solution :
Settings -> Interface -> Keyboard -> Pressing ESC Closing , and need uncheck both
Xn User
Post by Xn User »
Thak you ) this bug fixed )
